MAF says 310 grams/sec@5800rpm......
How does this correspond to what some of y'all 6.0 guys are seeing for NA MAF readings ??, I'm just curious to see how the LS1 heads/Shorty headers flow compared to whatever you guys are running....
Originally Posted by moregrip
I'm pulling 53lbs @ 5600rpm
That's because you're supercharged dipshit......and I'm STILL gonna hand you your ass NA :) That compares to about 41lbs/min for mine......you don't happen to have yor NA flow numbers do you Devin ?? |
That compares to about 41lbs/min for mine......you don't happen to have yor NA flow numbers do you Devin ?? oh yeah, I ain't getting any slower punk! |
HAHAHAHAHAHAHAHA !!!!!!
I've at least gotta give you that.......it looks like it's gettin' about time for me to start working on those twins |
I just saw 328 grams/sec @ 5900rpm a little while ago coming to work.....
I've read a few times that on these trucks if you multiply MAF grams/sec X 1.1 it gets you a pretty close RWHP number.....can anyone back that up ??? mroegrip: If that above calc works out that would put me at around 360ish and you around 440hp at the tires ....do you have a dyno run to compare that too ??? damn...I may finally have to admit that you *might* be faster than me grip |
Right now i am pulling in the low 50s lbs per min. I also have 408 and big heads
338 g/s in Shawns 2500hd with a small cam (220/224 572/577), muffler, 160 stat and 22 degrees total with a 12.8:1 AFR.
These can be way off though if someone is messing around with the MAF table when tuning, seen it a few times. |
