MAF says 310 grams/sec@5800rpm......
Old Jan 15, 2006 | 01:17 PM
Yelo's Avatar
Default MAF says 310 grams/sec@5800rpm......
How does this correspond to what some of y'all 6.0 guys are seeing for NA MAF readings ??, I'm just curious to see how the LS1 heads/Shorty headers flow compared to whatever you guys are running....
Old Jan 15, 2006 | 01:23 PM
moregrip's Avatar
what a rush!
I'm pulling 53lbs @ 5600rpm
Old Jan 15, 2006 | 01:35 PM
BBT's Avatar
BBT
Thats really decent airflow.......My setup max's out at 283 g/sec with the mods in my sig
Old Jan 15, 2006 | 01:36 PM
Yelo's Avatar
That's because you're supercharged dipshit......and I'm STILL gonna hand you your *** NA
That compares to about 41lbs/min for mine......you don't happen to have yor NA flow numbers do you Devin ??
Old Jan 15, 2006 | 01:56 PM
moregrip's Avatar
what a rush!
No, sure don't bro.
oh yeah, I ain't getting any slower punk!
Old Jan 15, 2006 | 02:07 PM
Yelo's Avatar
HAHAHAHAHAHAHAHA !!!!!!
I've at least gotta give you that.......it looks like it's gettin' about time for me to start working on those twins
Old Jan 15, 2006 | 10:38 PM
Yelo's Avatar
I just saw 328 grams/sec @ 5900rpm a little while ago coming to work.....
I've read a few times that on these trucks if you multiply MAF grams/sec X 1.1 it gets you a pretty close RWHP number.....can anyone back that up ???
mroegrip: If that above calc works out that would put me at around 360ish and you around 440hp at the tires ....do you have a dyno run to compare that too ???
damn...I may finally have to admit that you *might* be faster than me grip
Old Jan 15, 2006 | 11:56 PM
moregrip's Avatar
what a rush!
Come into to the light, feel the light, know the light, see my tail lights, so let it be written, so let it be done
Old Jan 16, 2006 | 07:16 AM
mwalls54's Avatar
Need More N2O Mod
Right now i am pulling in the low 50s lbs per min. I also have 408 and big heads
Old Jan 16, 2006 | 11:14 AM
hellbents10's Avatar
LS1Tech Sponsor
338 g/s in Shawns 2500hd with a small cam (220/224 572/577), muffler, 160 stat and 22 degrees total with a 12.8:1 AFR.
These can be way off though if someone is messing around with the MAF table when tuning, seen it a few times.
