as&m header question
Old May 27, 2003 | 11:30 PM
Phatchevy's Avatar
Default as&m header question
a friend of mine is considering getting some new headers and i suggested the as&m's. however, i have been reading some posts about people having some problems with the steering column and the header. has everyone that has done the as&m's run into this problem? is this problem easily fixed or do you have to cut certain things? thanks for the help..........
Randy
Old May 28, 2003 | 12:34 PM
YUKONTURTLE's Avatar
Default Re: as&m header question
I did not have that problem with the Yukon.
Old May 28, 2003 | 12:53 PM
Ryan23silverado's Avatar
Mine fit just fine clearing the column by a little more than half an inch. But, no two headers are exactly bent the same. They are awesome headers, but they could have sprayed a little thicker on the ceramic coating for the $700
Old May 28, 2003 | 01:13 PM
CurtD's Avatar
10 Second Truck Club
I had clearance problems with the steering shaft and the other side leaked on 3 cylinders.I talked to Ben @ asm and he sent out another set and they fit perfect
Old May 28, 2003 | 06:37 PM
MarineBlue03GMC's Avatar
Tech Fanatic
I just finished installing my ASMs. I have an 03 but everything should be similar to previous years, except maybe the cats.
Anyway everything went in no problem. The steering shaft is close but not so close that it caused a problem.
I didnt get the ceramic coating and the stainless looks really nice. I dont have any leaks and the power increase is DEFINITELY noticeable. The engine seems to rev faster and sounds CRAZY mean. It's actually amazing how much different it sounds with the headers.
The only thing you will have to deal with is going to a muffler shop after the install to have them weld up all the piping. For my truck this cost $150! Of course the shop I took it too isnt the cheapest but they do SERIOUSLY quality work. The muffler shop spent at least 2+ hours cutting off the factory cats, re-welding them, etc. This might have been because my truck is an 03. The 03's do have different 02 sensors so maybe the cat placement is different as well.
Anyway I highly recommend these headers! You won't be disappointed!
Old May 28, 2003 | 09:05 PM
L-EATER's Avatar
11 Second Truck Club
Yeah, I had clearance probs with the steering shaft and the pass side was a **** to put on. Not the hardest headers I have ever put on but definitely not the easiest. They sound just like stock and the finish already looks like crap. There are probably better headers out there but I went with what it seemed everybody else was running. Glad I went my own way on the torque converter, though.
Old May 28, 2003 | 09:38 PM
Tech Fanatic
Im surprised you think they sound just like stock! My engine sounds COMPLETELY different after the headers! The engine sounds more like a vette or camaro!
What finish did you get? The ceramic right? I guess the stainless is the way to go.
2500ZL1
Jan 25, 2016 06:30 AM
Stainless Works
13
Nov 5, 2015 03:31 PM
Martin4_8
Aug 13, 2015 07:31 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
