LY6 370 Build want to keep stock rods
Gents,
I bought an LY6 last year that turned out to be rusty enough inside that I want to bore it, and want to go 4.03 with it.
I would like to purchase forged pistons because this is a boosted motor (10-12lbs, pulley limited), but I want to keep the stock rods because this is a 600whp build, and the stock stuff is supposedly good to 1000 +/- a few based on tune.
Does Wiseco (or anyone else) make a forged 4.03 piston for the stock rod?
Anyone has a set they want to sell?
I'm not sure I have seen any for stock rods with that bore. Then again I have never looked.
You would want a compression height of about 1.33 for a stock rod with the block being decked to approx 9.239 or less depending on compression goals.
Thank you for the info on the comp height. 10.0 would be ok because of the lower boost number, but I would like to avoid having to buy an entire rotating assembly and push rods. If I can get by with pistons, I'd be happy.
Probably my best option:
https://www.summitracing.com/parts/w...make/chevrolet
Puts me 10.5-11.0 as for as comp goes, depending on head and block cutting
DSS makes a forged piston in a -5 variety that nets 10ish
https://www.summitracing.com/parts/d...make/chevrolet
Never heard of them, but they seem to have good reviews.
I might give them a shot. Ford guys seem to like them, and I read more good about them on the web than bad. Since I have limited myself to stock rod length, I have limited piston options: and those have been limited to A) probably too high comp for 91 and B) uncommon brand with an alloy not advertised.
Either way, still better than a eutectic piston, I hope
Because of the desire to boost this motor, the wrist pin being .945-.947 (depends on your source, I mic'd mine out at .9463) and the availability of pistons that have a .947 wrist pin, 4.03 dia AND LS3 valve reliefs: I have concluded I need a rod/piston package or a rotating assembly and a 408.
So back to the drawing board
