lt's and low end loss
Old Mar 29, 2008 | 01:27 AM
  #61
beastolds455's Avatar
Thumbs up Slow I Like That
When the O2s are slow to respond most of the time there on there way out
the front O2s are the main 2 that do most of the work all the back 2 do is check the fronts and monitor post cat like a critic sensor..
Old Mar 29, 2008 | 12:29 PM
  #62
jakebdb56's Avatar
Originally Posted by shupe
Stock O2's had 120k miles on them.
There's your problem. Any time I touch a high mileage truck I log everything to make sure it works before I start doing any kind of tuning. You can also mess up your O2's during the header install if you don't protect them while they're out of the exhaust. I saw this same situation a few weeks back while tuning a 02 ECSB with new LT's. His bank 2 front O2 was bad causing him to go crazy rich and mess up all the fueling. 110k miles on the clock, bought 2 brand new ones and we were on our way.
Old Mar 29, 2008 | 01:27 PM
  #63
timmer1's Avatar
I'm guessing you guys are right. I'm thinking it had nothing to do with the no muffler situation. It was only showing bank 2 being the one popping up codes. Had high voltage and no activity. I decided before putting mufflers on, I'd switch the o2 sensors around seeing as bank 1 wasn't coming up with a code. After switching them around, I have a code on bank 1. Must be my problem right?
Also, I've read in places that the corvette rear o2's work better for the front in our trucks after header installs. If I can use a rear o2 from a corvette on my front, can't I use one of the rear o2's that I don't use anymore? Are they the same except for the plugs? Let me know what you guys think. Thanks for the help. Tim.
Old Mar 29, 2008 | 04:40 PM
  #64
jakebdb56's Avatar
If it has the same plug it works just fine. That's what we did for the 02 5.3. Once we swapped it everything was good.
Also, disconnect your battery to reset the PCM. I believe this will reset your fuel trims so you can start from scratch when the computer re-learns for the headers.
Old Mar 29, 2008 | 04:53 PM
  #65
timmer1's Avatar
The rear o2's dont have the same plug, but I was going to splice the old plug into it. I just wasn't sure if the guts of the rear o2's on a silverado were the same as the front.
Old Mar 29, 2008 | 09:19 PM
  #66
timmer1's Avatar
I've gotta do something with this thing. I was going out to dinner with my girlfriend and on the way, a grand prix got up next to me wanting to play. Unfortunately, I was blown away by it because of this problem. My girlfriend was even picking on me about the power being gone. Horrible night needless to say.
Old Mar 30, 2008 | 12:38 PM
  #67
jakebdb56's Avatar
I wouldn't splice the connection at all. Just fork out the money for brand new sensors or find some that are used that have the right connection. A bad splice can bring a drop in voltage, which will in turn cause bad readings and produce the same problem you had before.
Old Mar 30, 2008 | 01:18 PM
  #68
timmer1's Avatar
by any chance, would you or anyone else know what the voltage is supposed to be to the 4 wires going to the o2 sensor. Is the voltage the same on the front and on the back? When I got my engine wire harness that wire was cut, so I had to splice the passenger side o2's in. There was 2 of each color wire, so I didn't know which wires went to the front and which to the back. Is there any way to determine which is the front and which is the back wires. I just had a bunch of cut off wires to work with when I did it.
Although I don't think that's the problem, no o2 sensor codes before the install of the headers. But if I could check the voltage, that would be reassuring to me.
Old Mar 30, 2008 | 01:21 PM
  #69
timmer1's Avatar
Odd to quote myself, but shortly after I got this code p0134 on bank 1, that code went away and now I'm back to p0154 on bank 2. Now I'm back to thinking either my wiring is messed up or back to the muffler problem.
Old Mar 30, 2008 | 02:47 PM
  #70
jakebdb56's Avatar
Most likely it's your wiring. Somewhere I have a diagram of the O2 wiring on my computer. The signal wire is 0-1v, and I think the power for the heater is 12v. I'll look around.
