LT pacesetter Guys w/ cats
Old Oct 15, 2006 | 10:38 PM
dkubricht's Avatar
Originally Posted by 1SlowHoe
Would this work?
how much did you have the extend the 02 wires?
your method looks what I will most likely do
Old Oct 15, 2006 | 10:41 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I didnt extend them at all. I just cut the sheath back enough to get them to reach. I bought extentions, I just havent put them on yet. (Lazy)
Old Oct 15, 2006 | 10:44 PM
1SlowHoe's Avatar
Also, after the tranny cross member I cut the drivers side pipe and slid a coupler on there. So when I have to drop the tranny I just unbolt the Y and the coupler. The passenger side is not in the way.
Old Oct 15, 2006 | 10:47 PM
gonzo 6.2's Avatar
Slow Z71,your pass. side header looks different that slows,I gather yours is cut short?
Old Oct 15, 2006 | 10:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Mine are cermaic coated dynatechs, but when I compared them to turbogibbs's pacesetters the pacesetter collector was all of about an inch longer. And my dynatechs are cut short to make 3" collectors instead of the 2.5s they come as.
Old Oct 15, 2006 | 10:54 PM
gonzo 6.2's Avatar
Dyna's,is that there Y pipe ? what did you do to it?The flanged in part?
Old Oct 15, 2006 | 10:56 PM
1slow01Z71's Avatar
No CurtD on the board made it for me and I supplied the mandrel bend. The factory flange was cut of the header and moved back to where the primarie is 3" diameter then cermaic coated. Dont really know what oyu mean by the flanged in part. I took two 3" cutouts and welded the flanges onto the collector side of the cutout then welded some 3" pipe to the cutouts and got it bent to meet up with the corsa.
Old Oct 15, 2006 | 11:08 PM
jakebdb56's Avatar
btw 1slow, i didn't know he was 4wd... looking at his sig I figured he was 2wd
Originally Posted by gonzo 6.0
The headers were to long so you had to move the cats backwards and you have the pipe welded up at the collector so if the trans has to come out you will have to cut the pipe.Am I reading this right?When you say bank 2 ,did you mean sensor 2 ? post cats
the headers weren't too long. I just extended the ORY so I could take it out without taking off the tranny x-member. Right now I can unbolt the two clamps at the headers and remove the ORY. I didn't weld the pipe to the collector. What i welded was the ORY itself, it comes in 3 pieces and I just welded part of it together instead of using a ghetto clamp. and bank 2 is indeed the post cat 02 sensor. With the 02 plugged in I didn't receive any error codes and all my components render "Ready" in the PCM
I wish I had pix, it'd be much easier to show you what I'm talkin about.
Old Oct 16, 2006 | 01:33 AM
gonzo 6.2's Avatar
I should up date my Sig with a current pic tired and wheeled
Attached Thumbnails LT pacesetter Guys w/ cats-img_0142.jpg
Old Oct 16, 2006 | 07:36 AM
treyZ28's Avatar
prob a futile effort as they wont work being that far back.
