LT-1 Fan Install Pic's Are Up
yea those are some nasty brackets. i bought some aluminum brackets about a foot long that have random holes in them. found them in the roofing part of home depot.they should work fine.are you connections on your fans at the bottom or top?
Bottom...
Two things I like about my install that you might want to consider:
1. I drilled a hole in the bottom of the LT-1 fan shroud and removed the wire looms going across the bottom of the radiator support so that the shroud would sit flat and flush.
2. I drilled a hole in the top radiator support(? You can see it in the pic) and used the factory radiator hose retainer to keep the hose in the almost stock position.
<small>[ May 26, 2002, 05:52 PM: Message edited by: RandyZ71 ]</small>
There is a bolt that comes up through the bottom support. I drilled the hole so that the bolt would slide up "into" the shroud. Also helps hold the fans in place if you keep the hole nice and tight.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RandyZ71:
<strong>There is a bolt that comes up through the bottom support. I drilled the hole so that the bolt would slide up "into" the shroud. Also helps hold the fans in place if you keep the hole nice and tight.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Like this...
<img src="http://home.swbell.net/greghud/fan" alt=" - " />
mr03silverado
Jul 17, 2015 02:15 PM
