LSXrT injector install help
Old May 27, 2013 | 12:09 PM
ihdude's Avatar
Default LSXrT injector install help
Working on installing my LSXrT intake on my truck and I'm having problems with my injectors fitting. My truck injectors are too big to seat properly on the intake. Whats going on with that? Will I have to drill them out to get my truck injectors to work?
Old May 27, 2013 | 01:04 PM
greasemykey's Avatar
you should have got a second set of orings with the intake. i did not have to drill anything to get mine to fit
Old May 27, 2013 | 01:07 PM
ihdude's Avatar
I got the new O-rings and they don't fit either. Too large. Too large for the smaller truck o-ring also. The injector hole is just too small for the injector to seat properly. Anybody else have this issue?
Old May 27, 2013 | 01:19 PM
bgray's Avatar
TOTM: June 2007
Wow that makes no sense. You OEM injector and oring should FALL into postiion. If thats not fitting you have something weird going on.
Post up a pic if you can. Ive pissed around with a lsxrt sooo many times I can help lol
Old May 27, 2013 | 01:52 PM
ihdude's Avatar
You can see the small ridge inside the injector hole. This is as far as the injector will go. It only goes as far as the bottom of the fuel injector. The hole is so small that the injector head itself won't go past the ridge.LSXrT injector install help-intake2.jpg
Old May 27, 2013 | 02:43 PM
Phantomx55's Avatar
Weird, I'm installing my Lsxrt intake today as well. My injectors seemed too small but the orings fixed that. I'm having a problem with the fast fuel rails not lining up with them though..
Old May 28, 2013 | 04:47 PM
craigsix's Avatar
my mechanic fabricated some a/c orings and shrink wrap. i heard corvette ls3 or 7 orings would work.
Old May 30, 2013 | 07:18 AM
bgray's Avatar
TOTM: June 2007
I had the same issue with mine, o rings supplied were to bulky. I got others from a local auto store.
You say the injector Doesn't fit down even with no orings?
Old May 31, 2013 | 06:02 PM
ihdude's Avatar
Yeah the injectors don't go in as deep on the FAST as they do the stock. Is that normal? Check out my injector photo. Does that look alright? Those are 8.1 marine injectors.
Old Jun 1, 2013 | 06:51 PM
bgray's Avatar
TOTM: June 2007
Mine sat the same as that
