lsa and cam?
Old Apr 17, 2007 | 06:35 AM
nathancalifornia's Avatar
From: military so i live in hawaii, born and raised in Tennessee
Default lsa and cam?
from my understanding, the lower the lsa in a cam, the lower the powerband is on a cam. and the higher lsa, the power band will be higher. is this correct or is it the other way around. ?
Old Apr 17, 2007 | 08:21 AM
BLACK04VHO's Avatar
basically yes, but theirs alot more to it then this. Duration is a big factor for when the power band kicks in also. Don't go below a 112 though in LSA.
Old Apr 17, 2007 | 08:58 AM
silver-mod-o's Avatar
Hunt&Fisherator
the tighter the LSA (lower number) the higher up the power will want to come on... this is definitely relative though... it has a lot to do with you ci displacement, exhaust setup, tune, etc etc... much more goes into figuring out your specific power besides just cam numbers.
Old Apr 17, 2007 | 09:40 AM
99/5.3w/hips's Avatar
why would you not go below 112 lsa? there are so many reasons TO go under 112 lsa
Old Apr 17, 2007 | 10:04 AM
yurs78's Avatar
What do you mean "the higer up the power will want to come on..."? Two identical cams, the only difference being the lsa there will be a big difference. If one is a 110 and the other is a 117 the 110 will have a peak hp about 400 rpms lower. The TQ peak will also be lower in the rpm and it will have more peak tq and average tq through out the rpms
This is just one instance, it doesn't mean these exact changes are a universal constant but I'm pretty sure in some cases similar results can happen.
This link helped me a lot:
http://www.hotrod.com/techarticles/1...ild/index.html
Old Apr 17, 2007 | 01:54 PM
Silver-Dollar's Avatar
99 - Have you dynoed yet to see your rpm range? what do you have your wot shift points set to? do you have any advanced ground in the 110 or is it straight up?
Old Apr 17, 2007 | 02:10 PM
havent dynoed yet, shift points are at 1-2 6k and 2-3 5800 right now, it's cam only right now so no need to go higher. It has a 4* advance in it so its technically a 110 lsa 106 icl. I like the advance right now but when I fine tune it better with the rest of the bolt ons I might change the timing set and get an adjustable one and take out the advance. Right now I am driving with no convertor and its completely streetable, pulls HARD above 3200 all the way up to my shift points right now.
Old Apr 17, 2007 | 02:16 PM
Sport Side's Avatar
LSA is meaningless without duration. One given LSA paired up with your intake/exhaust lobes will make the most average power in a given power range. Tight/Wide... Don't bother even thinking about it.
Old Apr 17, 2007 | 02:33 PM
word dont focus too much on lsa
Old Apr 18, 2007 | 08:27 AM
Say you had a cam that spec'ed out at 220/220 .581/.581 112+4. And you had a 224/224 .581/.581 cut down on a LSA that match the peak rpm of the 220/220 cam. Would the custom 224 make more peak power? How would the 2600 to 3600 rpms compare?
