LS9 cam into a 4.8, what parts do i need?
Old Aug 31, 2012 | 02:00 PM
Ieatpeople's Avatar
Default LS9 cam into a 4.8, what parts do i need?
i know this topic has been beat to death, and i've been using the search function here for the better part of 3 hours.
I just want a list of part #'s needed to swap the LS9 blower cam into my 4.8.
i know i need the front cover, the cam sensor, and a cam sprocket (1 bolt or 3 bolt?)
anything im missing, other than the part numbers?
note: this is not going in my truck, i have a 87 regal t-type i'm putting a 4.8 in, and i'm going to boost it.
Old Aug 31, 2012 | 02:04 PM
nonnieselman's Avatar
you goin to put a blower on it or turbo?
The newer stuff is 1 bolt.. the older stuff is the 3 bolt cams.
Send Beau an email, he can fix you up with PNs and get you a quote..
BNovak@scoggindickey.com
Old Aug 31, 2012 | 04:57 PM
Robert91RS's Avatar
LS9 still uses 3 bolt sprocket iirc. What year is the 4.8 out of?
Old Aug 31, 2012 | 05:25 PM
Beau@SDPC's Avatar
Trucks Sponsor
Thank ya sir!!
LS9 is the exception to the rule and uses a 3 bolt camshaft. I assume your 4.8 is a 24x. If so, you will need a LS2 Front Cover Kit, Cam Sensor Extension Harness, & a LS2 Timing Set. I keep everything in stock! Call me or e-mail me Tuesday and I'll get you fixed up!
Old Sep 2, 2012 | 07:42 PM
Ieatpeople's Avatar
thanks guys!!!
i'm planning on going turbo, since i have one laying around. just need injectors, do a bit of fab work, then get it tuned.
5.3Okasai
Mar 9, 2022 01:07 PM
chopperloco
Jul 10, 2016 10:45 PM
Suburban2500
Jul 19, 2015 04:50 PM
06 4.8
Jul 15, 2015 07:17 PM
