LS7 crank, will it fit?
Old Feb 14, 2008 | 04:17 PM
SS_bnoon_SS's Avatar
Default LS7 crank, will it fit?
Anyone know if the LS7 crank would fit the gen III block if the reluctor wheel is changed out to the one on my 6.0? Or if the reluctor wheel can even be swapped??? Reason I ask is that the LS7 crank seems to be cheaper than the aftermarket ones at sdpc http://www.sdparts.com/product/12568...rankshaft.aspx
Old Feb 14, 2008 | 06:04 PM
Bill Reid's Avatar
The LS7 crank snout is longer (for dry sump)... so , no, it will not work without it being machined. GMPP now has a forged 4" crank setup for standard wet sump applications (standard crank snout length)... 19171619. Using either crank without the LS7 Ti rods and pistons requires a rebalance. Both have the 58x reluctor wheel already installed. Yes, the reluctor wheel can be removed and a 24x reluctor wheel installed (with a special alignment tool).
Bill
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Jblake
Aug 17, 2015 12:59 PM
BennyB
Aug 1, 2015 08:48 AM
Ammadien
Jul 22, 2015 08:50 PM
