LS6 Intake Swap
#22
One question, What if you just got the ls6 alternator with bracket and LS6 water pump? Would that allow installation without any issues?
I'm looking at this picture
LS6
And this one
And it makes me think it might be easy to just swap brakets and pullys.
LS6
And this one
#23
dont forget the crank pulley, tensioners , idler
Yhat stuff adds up in $$$'s quick
Im not sure if the accesories will interchange with the bracketry????
It would look alot nicer like that though
#24
Wong,
Got me thinking
How much room you will have up front with your swap?
Just remembered saving this
this guy has alot of brackets and stuff that may help you out
http://stores.ebay.com/Trans-Am-Crea...QQftidZ2QQtZkm
Got me thinking
#25
Originally Posted by Kano
thanks man
I havent measured it out yet but,
the belt will be longer
I dont have any sketches, but I do have guides
to make more for others incase
this works out well
The wire loom is still there
but Im thinking of making another bracket to reroute this
this works out well
I've spoken to Allen at Nelson can make a harness to get rid of that ugly mess
if and when the time comes to pretty up the engine.
I've also spoken to Nasty Performance and yes, their setup is pricey, but very nice. Another option might be a 97-98 vette fuel rail as they were regulated at the manifold with a return line.
#26
To me it looks like the only difference is the drivers side brackets and pullys.
I'm also looking into the other plug the top and drill the front method. I think I'm going to try that first and if it doesnt work out use this method depending on cost of bracketry.
#27
Tdrum,
Im still running the stock pulley
I like the Nasty idea
Ive heard it said that the 97 rails dont have a FPR but it does have the
in and out lines????????
not exactly clear on that, ill see if I can find out ...
I know the IFR is scaled up in the stock bin files Ive seen
Wong,
I started to do that also
Mezieree makes several outlet thats threaded with NPT threads on one end...
look under fittings
http://www.meziere.com/index.php?pgName=20an
and you can find a tap pretty cheap on Ebay
Wong,
look under fittings
