ls6 build
Old Jun 14, 2010 | 08:14 PM
NVS05GMC's Avatar
Default ls6 build
I got a ls6 out of a 04 cts-v with 243 heads wana build a beast for a reg cab short bed 2wd looking to go 11's whats the best bang for the buck the motor needs bearing and possible crank. thinking maybe stroker
Old Jun 15, 2010 | 07:15 PM
Jake99's Avatar
You could go 11s without a stroker if you did heads, 230+ cam, intake, 4.56 gear, 4k stall on it. but a 383 kit would make it alot easer. if the crank is bad i say go for it, havent really seen any na 383s run on here yet.
Old Jun 16, 2010 | 09:24 PM
aQuickLS1's Avatar
From my understaning, one of the benefits to more cubes is that you can run a bigger cam without the loss of low end power and drivability. But if your going for best bang for the buck, a camed 346 with a shot of n20 should do the trick. But if you are going to be replacing the crank, then why not go with a stoker.
lxcoupe
Sep 6, 2017 08:24 AM
6.0l RST
Nov 23, 2015 11:30 AM
MA$TER_E
Sep 9, 2015 03:14 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
