LS2 Swap in RCSB
Old May 19, 2009 | 09:37 AM
bgray's Avatar
TOTM: June 2007
Default LS2 Swap in RCSB
Hey, just snowballin Idea's here. Lookin into a LS2 GTO and 6 Speed swap. Im doing the t-56 regardless, and aware of all the conversion parts needed to do so.
With the LS2, which intake manifold should i run? Im cable driven, and can upgrade to a 90mm TB if needed...
There is also some info about reluctor wheel or something?
Which wiring harness so I use?pcm?
Any info would be great, or maybe even any members who has done it before...
thanks alot guys
Old May 19, 2009 | 10:02 AM
chevrolet all the way's Avatar
ls2 motors have a reluctor wheel on the cam for the cam sensor instead of the whatever it is on out motors so it will have to have a different type of cam.
why not just build a 6.0 out of a truck to go in it for less and a direct swap with no worries
Old May 19, 2009 | 10:51 AM
1989k1500's Avatar
You'll have to get a conversion box for the crank signal and extend the wires for the cam sensor to the front cover. The knock sensors might be in a different spot too but I cant recall.
IIRC Speartech sells all the harnesses to put a gen IV engine into a gen III vehicle.
Old May 19, 2009 | 12:18 PM
bgray's Avatar
TOTM: June 2007
Yah I see lingefelter has a reluctor wheel module...so its jsut a matter of moving some stuff away.
Reason why im not going Truck 6.O is the car one has more HP, and I can buy a Motor and trans together(T-56) out of a GTO as a package. $$ is not the concern, If im goign to motor swap Im gonna get it right the first time
Old May 19, 2009 | 12:22 PM
bgray's Avatar
TOTM: June 2007
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Thats the lingenfelter module...That should convert it to 28x Crank
The Speartech ones are nice, but i dont need a complete new harness
Old May 19, 2009 | 01:09 PM
Rhoop24's Avatar
Call John at Speartech. He can make any harness. Plus go to his website he has a Gen IV in a Gen III truck on his website.
Old May 19, 2009 | 02:11 PM
bgray's Avatar
TOTM: June 2007
Called John at Speartech, and he said That the GTO LS2's have a 24x Reluctor in them so I dont need a module, simply jsut extend the Knock and Cam sensor wires and he even has extender wires for that!
Old May 19, 2009 | 03:20 PM
bgray's Avatar
TOTM: June 2007
Next order of Business...
I know i could switch my truck intake manifold and TB over to the LS2, but is that the best setup? I will be running heads and Cams in this LS2....? Or is the ls6 and 90mm TB a best bet?
Old May 19, 2009 | 04:23 PM
dkota1968's Avatar
If money isnt an issue get a fast 92 manifold and TB. Its a proven set up and it works. If your get n the complete engine then use the set up its coming with. I believe it was speartech who swapped in a LS2 but with a 6L80 into a RCSB but i could be wrong. I remember it being white, try a search. Are you saying you are runng a heads and cam package? couldnt really tell by the way you said it.
Old May 19, 2009 | 05:05 PM
bgray's Avatar
TOTM: June 2007
yah Im gonna run heads and cam package on it...
Whats pirce like on the manifold and TB Package
