ls2 intake w/whipple
Old Apr 12, 2005 | 07:26 PM
turbo595's Avatar
Default ls2 intake w/whipple
I got a question for you guys, I have a 2005 Denali SUV coming and was thinking using the whipple without the tune/electronics and using injectors and air to air. My question is, will the LS2 intake be an easier or better choice with the 90mm tb? Since the LS2 uses the shorter style injectors (I think), would I just use the 42lb injectors and not have to change anything else?
I haven't counted the Radix or the STS out by any means, but the truck will be here in another 3 weeks and I want to decide.....thanks for any help.
Old Apr 12, 2005 | 07:30 PM
99Silver6.0's Avatar
The LS2 intake actually chokes down to like 78mm right after the TB inlet. Ill try to find that picture of what im talking about. Its posted on this board somewhere. Keep ahold of the truck intake.
Old Apr 12, 2005 | 07:52 PM
turbo595's Avatar
The reason for swapping the intakes was to allow for the air to air intercooler. I thought the LS2 was based on the LS6 with a bigger opening and the use of the shorter injectors.....maybe I would be better off looking for an LS6????
Old Apr 12, 2005 | 08:02 PM
From the results I have seen, the LS6 would be better.
Old Apr 13, 2005 | 01:14 AM
Green Thunder's Avatar
LS2 SSR chokes down
LS2 car is open
Old Apr 13, 2005 | 06:53 AM
turbo595's Avatar
So what about the injectors if I use the LS2?
Old Apr 13, 2005 | 07:06 AM
Originally Posted by Flipper
LS2 SSR chokes down
LS2 car is open
Ah, nevermind me. I never saw that pic of the other intake!
Old Apr 13, 2005 | 07:51 AM
01Blackerado's Avatar
i thought Whipple took place of the intake manifold??
Old Apr 13, 2005 | 08:31 AM
ktmrider's Avatar
You would also have a problem with the TB as the mounts are different on the LS2 model.
Radix is an intake replacer, the Whipple is side mounted.
99bluefirebird
Sep 17, 2015 08:05 PM
chvy=power
Sep 8, 2015 11:06 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
