LS2 Intake on truck block - accessory drive clearance?
Old Jun 21, 2006 | 05:07 PM
Stroker2112's Avatar
Default LS2 Intake on truck block - accessory drive clearance?
Guys,
How do I fix an upcoming issue with my 408stroker project. I have an LS2 intake manifold w/90mm TB going onto my 6.0L iron block. Its my understanding that because thie LS2 intake is lower than the stock truck intake, that I'm going to have issue(s) with the accessory drive
....can the bracket be machined (take an 1" off).?...or is there a different bracket/parts that will easily replace the stock accessory drive parts. Anyone done this before?..
dg
Old Jun 21, 2006 | 06:52 PM
Quik's Avatar
5 year bitches!
same issues as the ls1/ls6 i do believe. when it comes to clearence
Old Jun 21, 2006 | 07:36 PM
Yelo's Avatar
Do a search on this, myself and quite a few others have done this swap in the past so there's ALOT of info floating around about it
Old Jun 21, 2006 | 08:49 PM
02sierraz71_5.3's Avatar
KANO did a good write up with pics
Old Jun 22, 2006 | 02:29 PM
vanillagorilla's Avatar
You could use the SSR manifold for the LS2. That would give you the clearance you need.
Old Jun 22, 2006 | 03:17 PM
Quik's Avatar
5 year bitches!
but i dont think its a 90mm setup, i know the one on the LS2 Tbss is 78mm
jmarkway
Jul 18, 2015 09:23 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
caviness
Jul 5, 2015 10:49 PM
