LS2 Heads and Intake on 5.3
Old Sep 16, 2008 | 07:58 PM
low5.3silverado's Avatar
Default LS2 Heads and Intake on 5.3
Would this be a good swap? What are the power gains?
Thanks
Old Sep 16, 2008 | 08:10 PM
Truckshop's Avatar
ls2 heads are 243 heads w/o the light weight valves. you have to mill them to not lose compression. which ls2 intake? car or truck.
Old Sep 16, 2008 | 08:28 PM
car intake
Old Sep 16, 2008 | 08:35 PM
Truckshop's Avatar
for the car intake you will have to make some modifications to your accessory drive. the truck intake will bolt right up. a few differences in evap hose routing and you need a torquerush adapter to use the 90mm t-body unless you are cable driven. but a relatively easy swap. i had the ls2 heads on my 5.3 and am using a tbss intake on my current 6.0.
Old Sep 16, 2008 | 08:54 PM
What kind of power did you pick up with the heads?
Old Sep 16, 2008 | 09:24 PM
InchUp's Avatar
https://www.performancetrucks.net/fo...d.php?t=424655
USMCvet0311
Jul 29, 2015 01:28 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
