LS2 cam in LH6
Old Oct 13, 2009 | 10:14 PM
CAPO's Avatar
Default LS2 cam in LH6
hi guys i have 5.3L LH6 with DOD supercharged i,m thinking of swaping the tbss 2007 cam on my engine , as long as i have the DOD lifters and ls2 cam lift is my MAX 0.525 i can run to keep DOD running fine other wise i have to change valve train system
my Q is should i expect slight gain with LS2 cam or its possible???
the LS2 cam i have is used removed after like 16 K and single bolt like mine
Old Oct 13, 2009 | 10:16 PM
charcoal03silvy's Avatar
You won't see much of ANYTHING gain wise. If you're wanting to cam it, get a custom grind for your setup. You got to pay to play!!
Old Oct 13, 2009 | 10:19 PM
CAPO's Avatar
here is LS2 cam spec
File Type: pdf
Old Oct 13, 2009 | 10:24 PM
CAPO's Avatar
i got this cam for free from a friend , and i would like to do that , but every body says with DOD you cant go more tha 0.525 lift
take look , here
https://www.performancetrucks.net/fo...=446702&page=2
i dont wana do this
Denali08
Aug 9, 2015 04:34 PM
Ammadien
Jul 22, 2015 08:50 PM
EscaTruck
Jul 20, 2015 11:42 AM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
