LS2 C6 cam
Old Aug 30, 2004 | 09:09 PM
chevymec's Avatar
Default LS2 C6 cam
Well It got slow at work and I got on the service computer and looked at the C6 info.
Engine Mechanical Specifications
Application
Specification
Metric
English
General
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LS2
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0017 in
Stroke
92.0 mm
3.622 in
Compression Ratio
10.9:1
Firing Order
1-8-7-2-6-5-4-3
Spark Plug Gap
1.02 mm
0.04 in
Camshaft Lobe Lift - Intake
7.81 mm
0.307 in
Camshaft Lobe Lift - Exhaust
7.77 mm
0.306 in
Valves - Valve Lift - Intake
13.27 mm
0.522 in
Valves - Valve Lift - Exhaust
13.25 mm
0.521 in
This thing ought to be pretty stout for a GM factory cam 522/521 lift. I looked up the price and I can get it for about $270 which I dont think is a bad price.
Old Aug 30, 2004 | 10:59 PM
chevymec's Avatar
ummm ,well i thought. The LS6 cam is bigger.... OH well
Old Aug 30, 2004 | 11:01 PM
10 Second Club
The LS2 cam can be only used in the LS2. Unfortunately, it can't be used in any of the gen III engines due to a difference in cam position sensor location.
Old Aug 30, 2004 | 11:04 PM
chevymec's Avatar
AHHH thanks for the heads up.
greedygenius
Sep 3, 2015 06:51 AM
Denali08
Aug 9, 2015 04:34 PM
Ammadien
Jul 22, 2015 08:50 PM
jmarkway
Jul 18, 2015 09:23 PM
caviness
Jul 5, 2015 10:49 PM
