LS2 90mm TB Whine
Old May 27, 2006 | 09:32 AM
DrX's Avatar
DrX
Default LS2 90mm TB Whine
Is it just mine or do all of these units whine. Mine is seems pretty loud when I pop the hood. Engine doesn't have to be running. I hear it as long as the key is in the run position.
Old May 28, 2006 | 12:51 AM
Holty's Avatar
Notorious BIG
Old May 28, 2006 | 09:22 AM
DrX's Avatar
DrX
Just wondering if this is normal operation or if there is something wrong with it.
Will have to do a vid. Definitely much louder than the stock 78mm TB.
Allso, has anyone looked at the LS2 TB at WOT? Mine does not go to full horizontal at 100% TP. I'd say that it opens to 75* if wide open is 90*. Don't see anything in the tune that would affect this. Could be the way it is supposed to operate.
Old May 28, 2006 | 08:22 PM
Holty's Avatar
Notorious BIG
bump for good questions that need answering
Old May 28, 2006 | 08:32 PM
krambo's Avatar
The whine is nothing to be concerned with. It will do it for a while with the key on. The whine will stop after about 20-30 seconds with the key on. Its just the motor assembly energized.
as for the blade,...can you monitor this parameter with a scanning tool? From what I remember, mine doesn't go full horizontal but gets damn close.
Old May 28, 2006 | 10:06 PM
DrX's Avatar
DrX
Scan tool says 100%. I guess what that translates to physically is determined by the TB/TAC module design. Again, just making sure that this is normal operation.
natejk
Nov 15, 2016 08:05 AM
gmcyukon
Oct 5, 2015 06:20 AM
Wolftrk99
Oct 2, 2015 08:17 AM
trxmxzx
Sep 29, 2015 07:42 AM
Chevy305
Sep 28, 2015 09:21 PM
