LS2 90mm Electric Throttle body to replace 78mm
Old Sep 9, 2007 | 07:20 PM
gen3performance's Avatar
Default LS2 90mm Electric Throttle body to replace 78mm
Does anybody have any information on replacing the 78mm tb with a 90mm.
My truck is a 2003 and the plugs are different on the two tb's. There is also a different number of pins in the two plugs. Six on the ls2 and eight on the existing. Any info will help greatly.
Old Sep 9, 2007 | 07:24 PM
nightrunner's Avatar
Mr. Obvious
what other mods do you have to support this TB? what intake manifold do you have? any other mods besides boltons?
i dont know the answer to your questions but unless you have extensive mods and a 90mm inlet on your manifold, you dont need it
Old Sep 9, 2007 | 07:43 PM
I am running a 427 with l92 heads and truck intake.
Old Sep 9, 2007 | 11:06 PM
2004SSS's Avatar
youll need a ssr intake or you can convert to a car style or vic jr. pm drx for a harness adaptor .
Old Sep 10, 2007 | 01:04 AM
14 Second Truck Club
I don't believe that it'll work on the regular truck intake. It has to be an intake off of a SSR/TBSS that already has an opening big enough for the 90mm tb.
Old Sep 10, 2007 | 05:47 PM
Sorry i didn't clarify earlier. The intake is a truck intake from a 2007 escalade which has the large opening.
Old Sep 10, 2007 | 06:49 PM
mwalls54's Avatar
Need More N2O Mod
you need to either get a harness from speartech for the 6pin to 8pin and a 2002 tac module and some guys have got the harness from drx.
Old Sep 11, 2007 | 11:33 AM
SS_bnoon_SS's Avatar
Dr X harness is the way I have gone, much easier than the Speartec/TAC module way IMHO.
Old Sep 13, 2007 | 08:03 PM
Sounds good. I talked to DrX and he was a lot of help. Probably going that route.
Old Oct 22, 2007 | 09:23 PM
amadeospike's Avatar
Who is DRX?
