LS1edit users ?
Old Jul 27, 2003 | 08:19 AM
67SS509's Avatar
10 Second Truck Club
Default LS1edit users ?
Trying to make a 6.0 with cam and headers idle. I don't have LS1edit but curious how you do this with it? Is it done by increasing air flow thru the IAC (Idle Air Control)valve?
Old Jul 27, 2003 | 08:57 AM
parish8's Avatar
single digit dreamer
Default Re: LS1edit users ?
prety sure most bigger cams need a higher idle. that may be all you need. a really lumpy cam may set false missfire codes too and with edit you can shut that test off. there may be other things to do also but those are the only 2 i am sure of.
Old Jul 27, 2003 | 02:00 PM
hohl's Avatar
A combination of IAC and idle speed will help you make it idle. Some people will say that in addition to changing your IAC and idle speed you will benefit from editing the VE table in the idle rpm ranges -- I haven't tested that since I have had no problems making the cam you have idle in a 5.3 and then in a 5.7. I upped my IAC and idle speed -- no throttle body hole drilling.
Old Jul 27, 2003 | 02:37 PM
67SS509's Avatar
hohl,thanks for the reply. You lost me when you say "IAC and idle speed". I thought regulating air thru the IAC is what makes idle speed go up or down. Is there another function I'm missing here?
Old Jul 27, 2003 | 06:02 PM
Ryan23silverado's Avatar
The Volumetric Efficiency table does work! If you hunt at startup because of a cam that has low lsa, try changing the VE table. It worked awesome on my truck.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Superman09
Sep 25, 2015 05:55 AM
DrX
Sep 18, 2015 08:53 AM
the owl
Sep 4, 2015 04:09 PM
