EGR MOD GONE BAD!!!! need help
Old Jul 27, 2003 | 07:56 PM
RacerBill's Avatar
Default EGR MOD GONE BAD!!!! need help
well i just f'd up my egr mod and cut too much off and cut the pipe and now i have to way to fix it ......that i know of....please help... i need to go to work in the morn....and now i have a cut egr hose...what should i do?
Old Jul 27, 2003 | 08:08 PM
phenyxTA's Avatar
Default Re: EGR MOD GONE BAD!!!! need help
If you have a way to plug the hole in the manifold you can just unplug the electrical connecter to the egr and it'll run fine, you'll just get a service engine light. At least that way you can drive it.
Old Jul 27, 2003 | 08:12 PM
Banned
how did you manage to cut the tube? i would do exactly what phenyxta said.
Old Jul 27, 2003 | 08:45 PM
RacerBill's Avatar
well the thing is.....i cut some off of it and well it looked like there was too much still in the Tb hole ... i thought it was supposed to be flush to the inside and well a little note to neone that will be doing this in the future ....ONLY CUT TO THE CREASE.... there should be a little hanging in the tb right?....right now i have some jb weld setting on it trying to do the trick where i have a way to get to work in the morn....ne more replies would be helpful...
Old Jul 27, 2003 | 09:50 PM
twobit's Avatar
I did the same thing to mine a while back. Fortunately a friend of mine had an extra one laying around.
You can use a expandable freeze plug(i think thats what its called). The size you will need is 1 3/8 but do a search to make sure on the size.
dhorner77
Sep 11, 2015 05:10 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
Dezmo
Sep 9, 2015 02:09 AM
Pimpinpete
Sep 8, 2015 07:39 PM
