LS1Edit help
Old May 9, 2004 | 06:57 PM
BlownAlaskan's Avatar
Default LS1Edit help
I have a problem with edit. In LS1prog it will not link up to the pcm because I am getting comm errors. LS1edit will not open any files either. You guys have any ideas?
Old May 11, 2004 | 08:37 AM
Have you tried to read the PCM to verify comms?
Is the PCM still working?
With individual liscense, you can only read files from similar year/model vehicles. I can't read any 'vette or f-body files with my truck version of edit. Can you open your last flash file?
Old May 12, 2004 | 01:36 AM
Yea, it seems that I am getting a comm error. Don't know how to tell if the pcm is still working. Ideas?
Old May 12, 2004 | 07:18 AM
BigKID's Avatar
Sounds like you may have a bug in then program itself. Have you tried uninstalling then reinstalling edit?
Old May 12, 2004 | 01:10 PM
yes, tried that. I have been emailing ken kelly, but we have not got the problem figured out yet.
Old May 12, 2004 | 01:19 PM
BigKID's Avatar
Can you use other things out of that serial (com) port like say.. Autotap?
Old May 12, 2004 | 03:23 PM
yes, ports work fine as does efilive. Also, the editor is now working. Just cant seem to read/write to the pcm. ???
Old May 12, 2004 | 04:28 PM
BigKID's Avatar
Then that sounds like it is in you cable/module then. Are you useing the same cables for edit you are using for efi? If not try swapping cables and see if that fixes it.
954RR
26
Aug 4, 2003 01:20 AM
Procharged LM7
Mar 6, 2003 11:53 AM
Yelo
Feb 28, 2003 04:26 PM
MarineBlue03GMC
Nov 22, 2002 07:23 AM
SSHOTRODSCOM
Sep 29, 2002 12:58 AM
