is an LS1 throttle body the same/similiar to a 5.3 tb?
Old Aug 30, 2002 | 08:30 PM
Jim85IROC's Avatar
Default is an LS1 throttle body the same/similiar to a 5.3 tb?
My father's 2000 GMC is experiencing a sticking throttle off idle. I'm aware of the GM technical service bulletin. He's 1,500 miles out of warranty, but since it's been doing it for a while, we're hoping that the dealer will honor it. If not, if we can't fix it ourselves we're going to be needing a throttle body. Since there's a ton of LS1 guys replacing theirs with aftermarket stuff, I was hoping to pick one up cheaply, but obviously if it doesn't fit, I can't do that. If somebody knows whether they interchange or not, I'd appreciate it. Thanks.
Nice website by the way. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
Old Aug 30, 2002 | 09:16 PM
CashDudeHomie's Avatar
Default Re: is an LS1 throttle body the same/similiar to a 5.3 tb?
Did you try cleaning it? It would still probably stick but not as bad maybe. To answer the question I believe they are the exact same, but maybe someone can reply that knows for sure. Welcome to the site. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 30, 2002 | 09:26 PM
Jim85IROC's Avatar
I haven't tried cleaning it yet. Right now I'm just trying to cover all of my bases incase GM doesn't warranty it. We'll definately clean and inspect it first, but I want to know as much about them and what interchanges ahead of time.
Old Aug 30, 2002 | 09:33 PM
XLR8NSS's Avatar
Adkoonerstrator
I'll try to check my car and truck tomorrow before I leave to see if they have the same TB.
The TB on my 2000 GMC is sticking also and I've cleaned the hell out of it. It stopped sticking for a while after I cleaned it but, now it's right back to sticking again.
If it's just a tight throttle blade it wouldn't be hard to just take it out and sand the edges down just a tiny bit. I might try that with mine. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
PS - If there is a TSB on something GM should fix it whether the vehicle is under warranty still or not.
Old Aug 30, 2002 | 09:34 PM
oxidizr's Avatar
Moderator / Sponsor
The "Body" itself is the same casting but the throttle arms and TB preheat tubes are different from year to year.
Richard
Old Aug 31, 2002 | 12:54 AM
TA/30th 1002's Avatar
A quick fix is just to give the idle stop screw a little turn, it takes a small alen wrench. You'll most likely not notice any differance in driveability ather than the throttle blade dosent bind up in the bore any more (espesialy(sp) on a cold start) ... see after a while the idle stop tab bends a little from normal use, this results in the blade closing too far within the bore and sticking.
I give this job a; <1 Beer Rateing>
Hopes this helps some ... Ron
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
Black-Syde
Jul 6, 2015 02:12 PM
