LS1 in tahoe.. cam ideas?
Old May 1, 2009 | 08:36 AM
soulefood's Avatar
Default LS1 in tahoe.. cam ideas?
guys im gettin ready to throw an LS1 into my tahoe... what cams have you had great luck with. keep in mind i dont want anything i cant use the stock rockers with and it needs to be good for towing, you know some low end grunt!
Old May 1, 2009 | 09:55 AM
TXsilverado's Avatar
216/220 or 212/218
Old May 1, 2009 | 10:08 AM
blueflamed03's Avatar
I have a Yukon, would like to see pics when complete and how you like it follow up...
Old May 1, 2009 | 10:17 AM
BlackGMC's Avatar
Resident Retard
218/218 .58x/.58x 110+s
Old May 1, 2009 | 12:41 PM
BigKID's Avatar
I have an LS1 on my engine stand I am planning to rebuild for my Tahoe. I figured the 214/216 .545/.535 113+4 custom Futral grind I had in the 5.3L when it was in the truck will work nicely. Since you plan on towing with it, i would say stay in the 21x duration range, higher lift, moderately tight LSA with a few degrees of advance ground in.
Old May 6, 2009 | 05:36 AM
soulefood's Avatar
ok so a couple things i need to understand... i get kinda confused on cams. LSA like a 112 vs a 114 is just gonna be idle quality. I know what lift is... but how does the duration affect the powerband characteristics? lets hear it cam guys!
Old May 6, 2009 | 06:02 AM
soulefood's Avatar
blue flamed... have you thought about going to an ls1? I actually got luck and scored a 5.3 long block minus the intake for 50 bucks. the guy said it had a rod knock and when i pulled it apart it was just a lifter. either way i scored some 3.908 forged pistons on eagle i beams... thats .010 over a stock ls1 should be interesting in the tahoe! ill let you know the closer i get!
Denali08
Aug 9, 2015 04:34 PM
JordanH
Aug 8, 2015 07:59 PM
jaypowe11520
Jul 29, 2015 07:59 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Black-Syde
Jul 6, 2015 02:12 PM
