LS1 pantera coil packs
Old Aug 10, 2008 | 04:01 PM
dirt track racer 81's Avatar
i think our ignition system already does that. the msd coils dont do that the msd boxes do the multiple spark
Old Aug 11, 2008 | 06:26 AM
nemmarick's Avatar
nice thanks for the help guys! ill use that money i wouldve wasted on cam and custom Y pipe- i herd the Z06 cam was the way to go? any other opinions?
Old Aug 11, 2008 | 08:15 AM
truckmann's Avatar
Z06 cam is good if you are planning on F/I. Otherwise it's a little small and not worth the time to put it in IMO. For N/A I would look into the area of a 212/218 up to 224/224. Also about any cam worth putting in will benefit from a stall of at least 3000 rpm.
Old Aug 11, 2008 | 08:17 AM
nemmarick's Avatar
what if i dont plan on going FI and staying N/A till next summer? should I get the 224/224 then swap out for Z06 when i go FI?
Old Aug 11, 2008 | 08:37 AM
MeanZ71's Avatar
Thats a big pain in the *** to swap out cams, If know your going FI just go with the Z06 cam you will still see some gains. Not worth it to waste money on a 224 if your gonna take it out in a year IMO
Old Aug 11, 2008 | 08:58 AM
nemmarick's Avatar
Thats what i figured, thanks for the help.
Old Aug 11, 2008 | 09:16 AM
MeanZ71's Avatar
No problem, you can find used Z06 cams on LS1tech all the time. 02+ were a little better
Old Aug 11, 2008 | 10:58 AM
On my 4.8 i went with the z06 cam and 3 months later swapped it out for a 222/222 comp cams. It's a good cam but i got the comp cams for cheap so went ahead and did it.
Old Aug 11, 2008 | 11:33 AM
nemmarick's Avatar
how much better is the z06 cam then the comp cam? i figured the comp cams would be good for FI and N/A, but is the z06 cam that much better for FI?
Old Aug 11, 2008 | 12:36 PM
Wilde Racing's Avatar
How do I change this text
Depends on the cam from comp, the z06 is just a good cheap cam that will give good gains with F.I. if money is no object get a custom grind comp that fits you needs the best.
