LS1/LS6 intake revisited
Old Jan 6, 2004 | 09:33 AM
Is that bracket going to be made available to the general public? Any idea on price?
Any updates or new ideas yet?
Old Jan 6, 2004 | 11:07 AM
kevinc's Avatar
Are the fuel rails, injectors and connections the same on a truck set up as on an LS1/6 set up?
Kevin C
Old Jan 6, 2004 | 11:18 AM
BigTex's Avatar
Kevin C
No, truck injectors take a different electrical connector, are 5/8ths inch shorter than the LS1 injectors, and have a differnet fuel rail. But you should be able to modify the truck rails to fit on the LS6 intake and reuse the truck injectors.
Old Jan 6, 2004 | 11:22 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I can do the brackets for $70 each; $90 including the correct belt.
Old Jan 6, 2004 | 11:29 AM
Speartech's Avatar
Originally Posted by Scream
Do you think it would work if you used the truck pump's nipple on the F-car pump? I have a car pump on my LS1 and access to an LS1 intake and fuel rails from someone that went to a Weiand.
Hmmm.......
I think if you could pull the F-body pulley about 1/4" out farther, it will work as is. I haven't tried pulling one of the water pump pulleys off, so I don't know if there is room to spare or not.
Old Jan 6, 2004 | 11:30 AM
Scream's Avatar
MOOBIES Moderator
What else would be needed? I'm putting my motor in this weekend, dangit!
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
