ls1 intake injector ?s
Old Mar 11, 2004 | 05:41 PM
bigguy75inches's Avatar
ok,,, its more like an inch and a half difference in the height of the fuel rail, so i guess i will have a maching shop make me a spacer.
Old Mar 11, 2004 | 10:36 PM
Ryan23silverado's Avatar
i think injector placement -as far as the amount they stick into the manifold is kind of critical.
Old Mar 11, 2004 | 10:53 PM
Texas Terminator's Avatar
11 Second Club
an inch and a half!! something is definately wrong. i only had to install small spacers that were only like 5/8ths of an inch. and do not enlarge the hole. they will fit, something else is wrong. this is what i had to work with. stock on left, racetronix 57's on the right.
Old Mar 11, 2004 | 11:00 PM
hmmm... did you use stock truck fuel rails? or the ls1 fuel rail? im using stock truck rails. my intake is a just a ls1 intake, not a ls6, would that make a difference?
also the bolt holes for the fuel rails are slightly different, one hole lines up perfect, the other is off about 3/4 of an inch.
Old Mar 11, 2004 | 11:01 PM
11 Second Club
stock fuel rail for now. you will have to bend (slightly and carefully) the crossover tube. look at my prior post edited for pics of my injectors. are yours similar? oh yea, you will have to enlarge/modify the hole in one direction to acomodate the new injectors. the longer injectors will make the rails move, one to the rear and one to the front. i just used an appropriate sized drill bit to enlongate the hole.
Old Mar 11, 2004 | 11:03 PM
also my rc 42# injectors look just like that stock injector,, by the looks of your 57#rs, they are alot taller, and have a smaller tip. thats why yours fit, and you only have 5/8s of a gap.
Old Mar 11, 2004 | 11:04 PM
11 Second Club
can you post a pic of your injectors? vs the stock ones?
Old Mar 11, 2004 | 11:07 PM
i dont have a stock one onhand, but ill post a pic of my rc injector is 2 minutes
11 Second Club
do you see where the taper is at the bottom of the injector? that is where it should seat in the intake. the top will sit flush against the fuel rail and should (mine did) use the original retiner clip.
