LS1 Intake on 5.3 with returnless fuel system
Old Dec 26, 2006 | 08:43 PM
  #21
dirt track racer 81's Avatar
Originally Posted by DozerDan
Will these fit LS1 injectors?
It says they replace GM12085491 which is the connectors for the LS1 injectors...Don't look right though
look over on ls1tech and see if you can find a wiring harness really cheep
Old Dec 26, 2006 | 08:54 PM
  #22
Phantom's Avatar
11 Second Club
I'm lookin...I'm lookin for some rails too...where'd you get yours, what kind are they?
Old Dec 26, 2006 | 09:16 PM
  #23
mine are nasty performance fuel rails..i got mine from a buddy in town..his bro wrecked his firehawk and i got the wiring harness from it..the wires to the injectors are all color coded and ls1 harness has the same colors plus numbers..easy to hook up..by the way you could have put a better pic of my engine in the first pic..
Old Dec 27, 2006 | 06:32 AM
  #24
TurboGibbs's Avatar
speed inc has a good deal on rails and Nelson's has the inj pigtails.
Old Dec 27, 2006 | 09:12 PM
  #25
Phantom's Avatar
11 Second Club
OK, gathering parts for the swap. Intake is on the way, Going to use stock LS1 injectors, Summit fittings and lines, some kind of billet fuel rails , looks like I can use my stock water pump with slight modifacation.
Do I need a car map sensor? What relocation brackets? Different Accessories?
EDIT: Just need idler relocate bracket and can keep accesories
Anything else???
Old Dec 30, 2006 | 08:04 PM
  #26
Phantom's Avatar
11 Second Club
Can someone give me the part number(s) for the fitting(s) i need to connect the aftermarket rails to the stock fuel line please?
Old Dec 30, 2006 | 08:18 PM
  #27
v8
17,16,15,14,13,12,11 Drvr
here this might help ya
https://www.performancetrucks.net/fo...d.php?t=375959
Old Dec 30, 2006 | 08:22 PM
  #28
v8
or this one
https://www.performancetrucks.net/fo...highlight=kano
Old Dec 30, 2006 | 09:45 PM
  #29
Kano's Avatar
I think its this one
call Jonaton at thunder racing he will know for sure
142-54028 F.A.S.T. LSX 3/8 to -6AN Fuel System Conversion Fitting (This is a 3/8 push connect coupling for a OEM fuel line to convert it to a -6AN Male fuel fitting for use in conjunction with the FAST Fuel Rails)
Old Dec 31, 2006 | 07:59 AM
  #30
Phantom's Avatar
11 Second Club
Originally Posted by v8
Yeah i've got this one book marked but you used stock rails or not aftermarket anyways and didn't use the fitting I need.
Thanks I'll give him a call to be sure.
