Ls1 hot cam
Old Nov 19, 2005 | 06:14 PM
Default Ls1 hot cam
has any one put a ls1 hot cam in a 6.0 Lq4 i have one layin around just wanted 2 know if thats a good cam for these motors its 219/228 .525/.525 112 i am gonna have a nelson tune pretty soon and thought i would put the cam in before i get it tuned
Thanks
Old Nov 19, 2005 | 07:56 PM
SlvrSierra4.8's Avatar
Thanks
Man I've been wondering the same thing for some time now. I have never heard of anyone running it in any of the truck motors 4.8, 5.3, or 6.0. So I'm curious too...
Old Nov 19, 2005 | 11:41 PM
Deckhand's Avatar
The hotcam is a relatively good cam for someone who wants a cam thats inexpensive, provides decent power, and with no valvespring maintainence. The downside to the cam is its drivability characteristics, but I think most of my drivability problems are because my tune is off. Surging, stalling, bucking and dying are an occurance... but you could tune most of it out. I have tci 3000 stall and I would at least recommend that. I kept the same pushrods and just used the ls6 springs. The hotcam kit also comes with valve spring seats, which require you to remove your valve seals, and seats (shims). However, from 2002+ the stock heads already have seats that are shimmed to correct height, so you wont need to change those out.
Bottom line, if your going cheap, loping hard, decent power with some drivability problems, but take the time to tune on it, its a good cam.
If you want to spend a little extra money, you could get a cam that has newer technology, higher lift, and more aggressive lobe design. Also you could probably achieve better drivability, more power, and less tuning issues as compared to the hotcam.
Im putting together a new combination for my truck which will be a vortech blown 6.0l, and I went with a cam motion custom grind. You may want to submit a cam request to see what they recommend for you and your trucks specifications. http://www.cammotion.com or contact some sponors to see what they recommend.
Old Nov 20, 2005 | 01:40 PM
1badgmc's Avatar
Wanna sell the hot cam??
Old Nov 20, 2005 | 02:01 PM
so basically since i have a 2003 lq4 with 317 casting heads i dont need to install the spring shims just the springs that came with the cam that saves alot of trouble
Old Nov 20, 2005 | 10:44 PM
Deckhand's Avatar
I am not selling the cam as of yet, as I may use the motor to transplant into another project. But if I decide to sell it, ill let you know.
Yes.
Old Nov 21, 2005 | 02:49 PM
From my experience any hotcam isnt worth it. For a few more bucks get a custom-grind CompCam or a TSP cam.. It is definately worth it for the money!
superchomper2003
Aug 26, 2015 09:39 AM
Denali08
Aug 9, 2015 04:34 PM
jaypowe11520
Jul 29, 2015 07:59 PM
06 4.8
Jul 14, 2015 08:09 AM
Black-Syde
Jul 6, 2015 02:12 PM
