LS1 Heads
Old Oct 12, 2007 | 10:29 AM
colekill's Avatar
KickinAssAndTakinNames
Default LS1 Heads
if i were to buy used Ls1 heads on ebay, what should the casting number on the heads be?
also, has anyone else bolted on some Ls1 heads? Is it as simple as just bolting on?
i here it's about a 30HP gain, going from (not sure) 1.25 inch valves to two inch valves with the Ls1 heads.
Old Oct 12, 2007 | 02:49 PM
Quik's Avatar
5 year bitches!
241s if you are going to a ls1 head
Old Oct 13, 2007 | 03:48 AM
silver-mod-o's Avatar
Hunt&Fisherator
FYI my friend...
https://www.performancetrucks.net/fo...d.php?t=402674
Old Oct 13, 2007 | 03:49 AM
Hunt&Fisherator
you have 1.94 intake valves in your truck heads... 1.25 is TINY!!!!!!!!!!!
Old Nov 14, 2007 | 06:46 PM
map0711's Avatar
Default ls1 853 casting heads is it worth the work
like the title say i can get the heads and intake, haven't seen them in person but their from a good friend so i trust him, he says the intake has a small silver plate that says ls1 performance or something like that, what yall think, will this help my set up?
Old Nov 14, 2007 | 06:58 PM
joshua022's Avatar
I thought the 5.3's had 1.89 intk and 1.55 exhst valves??
And wouldn't he need to get them milled???
And I wouldn't do the intake swap to an LS! intake..IN another forum WCCH flowed all of the different intakes and the truck intake flows better than the LS! if your going to do a swap atleast make it an LS6 intake.. IMO
Old Nov 16, 2007 | 10:36 AM
Yogi Bear's Avatar
Don't waste your time on the LS1 intake. Here is some hard data.
axekick
Sep 7, 2015 07:01 PM
nrmskate
Aug 11, 2015 02:44 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Denali08
Aug 9, 2015 04:34 PM
Black-Syde
Jul 6, 2015 02:12 PM
