LS1 fans installed with dyno results
Old May 14, 2003 | 08:57 AM
Default LS1 fans installed with dyno results
Well, it's a pretty straight foward job. Used a Haydon mounting kit, Haydon adj fan controller and LS1 fans from a 2000 Z28 with 7000 miles on it. The LS1 fans fit up just right to the radiator.
Before results on the dyno were about 259rwhp and after was 265rhwp. So it gained about 6hp/6tq across the entire graph. Should see some track results tonight.
Old May 14, 2003 | 09:51 AM
11 Second Club
Default Re: LS1 fans installed with dyno results
Does the Haydon mounting kit include wiring and relays, or are there actual mounts for the fans?
Old May 14, 2003 | 10:22 AM
I used these kits
Haydon Part# 77528- This has the adj control, relay, fuse and wires.
Haydon Part# 77008- This is just a simple set of four clips that mount the fans to the radiator.
I also bought two GM weather pack connectors to run to the fans which were part# 12101917 from GM.
I should get some pictures up, it should really look like a factory job once I get the conveluted tubing over some of the wires.
Old May 14, 2003 | 11:17 AM
11 Second Club
who did you gets your parts from?
Old May 14, 2003 | 11:42 AM
CashDudeHomie's Avatar
Make sure you put some foam between where the top of the fan shroud touches the back of the radiator or you might end up with a bent cooling tube like me.
Old May 14, 2003 | 12:15 PM
QIKSILVR's Avatar
Were you pleased with the dyno numbers? Seems a little low doesn't it? I thought 10+ hp/tq for sure. Guess you can't believe all the numbers a product claims.
Old May 14, 2003 | 01:55 PM
Six horsepower from removing a clutch fan is great.I have electric fans and a 6hp gain sounds about right.The best thing about removing the fan is the improvement in engine response.
Old May 14, 2003 | 02:10 PM
XLR8NSS's Avatar
Adkoonerstrator
Well, it doesn't sound like much but, it's all the little things that start adding up.
It's sweet having a dyno ***** in the truck section.
John
Old May 14, 2003 | 02:16 PM
Now if I can only get a scanner sometime soon to post these graphs!
I got the Haydon parts from Carquest.
Hope to bust a 15.0 tonight at the track.
