ls1 fan wiring schematic
Old Jan 27, 2006 | 06:31 PM
white1's Avatar
Originally Posted by ZRO26T
Matt, don't forget about the Black C10. Holla when you got time.
Got yours sitting in the bed room. Maybe Sunday??
Old Jan 27, 2006 | 06:34 PM
white1's Avatar
Your truck doesent look like his
Old Jan 27, 2006 | 08:20 PM
SnakeOiler's Avatar
Originally Posted by SS_bnoon_SS
Nice write up on the fan wiring. Any chance you could elaborate on the connection used for the AC turn on? I noticed that you said no wire splicing was done and haven't been able to track down how you would have made the connection at the fuse box without a splice of some kind... Is there an open spade connector or something that I'm not seeing???
I took the terminal out of the connector, cut it off, used a new terminal and crimped both wires into it.
Old Jan 27, 2006 | 09:54 PM
SS_bnoon_SS's Avatar
Ahhh, gotcha!
Old Jan 28, 2006 | 10:39 AM
WhiteChevy3's Avatar
how had is it to wire them up to a manual on/off toggle switch??
Old Feb 1, 2006 | 10:42 AM
acdcgcsc's Avatar
Banned
superior harness company can get you a fan relay harness that look good try them you can go to there web
Old Feb 1, 2006 | 11:10 AM
white1's Avatar
Not hard. Use the wire that would go to pin 42, and run it to a switch that goes to ground. If you need some help, PM me.
Old Feb 1, 2006 | 11:47 AM
You can run it to both pin 42 and a manual switch to ground too for the best of both worlds.
Old Feb 1, 2006 | 11:58 AM
Colby 04's Avatar
What does pin 42 read when the fans are idle?
Old Feb 1, 2006 | 12:09 PM
Should be open...
