ls1 fan wiring???
Old 06-02-2009, 12:19 AM
miller white's Avatar
Default ls1 fan wiring???
Just got some ls1 fans for my 04 rcsb. I know everyone says go with nealson wiring harness's. But I know there are some harness guys on here have built and work just as good. Anyone have a diagram of a good set up? Thanks.
Old 06-02-2009, 10:07 AM
neilownz's Avatar
search and you should find some diagrams of the nelson one. 2 relay is without a/c and 3 relay would be with a/c turn on.
Old 06-02-2009, 07:58 PM
SilverDog's Avatar
I used the diagram that is posted. It is the (SLIGHTLY MODIFIED) 05+ GM diagram so I would use it over all other diagrams. Doesn't work off the Nelson style A/C switch but off pins 42 and 33 which I recommend since you truck is a 2004(like mine). I have posted in several threads with electric fan info plus created some. https://www.performancetrucks.net/fo...d.php?t=437058
Old 06-02-2009, 09:17 PM
neilownz's Avatar
I still havent gotten mine working. I think i might try just putting that blue pcm wire from the nelson harness to one of those cylinder head sensors. Might have blown a relay too, but if you are using ls1 fans it shouldnt be a problem.
Anyways it would be tough to build a harness for less than 100 bucks... plus the time hassle.
Old 06-02-2009, 09:25 PM
I have a gauge for that
Atomic's Avatar
this is the one i used
I added the bottom part if you want to do it manually
cost of making my harness was about $40 for all the parts, took about an hour.
Old 06-02-2009, 09:26 PM
nonnieselman's Avatar
that last 5 harness's ive put together worked just fine off that diagram above.. but i modified it for the Pin 42 and 33
Old 06-05-2009, 09:06 AM
still completely lost guys....
Old 06-05-2009, 11:58 AM
11.0 Moderator
SUX2BU's Avatar
Yeah, i should have built my own. Mine has messed up twice now.
Old 06-05-2009, 12:38 PM
Atomic's Avatar
Made a slight change to my diagram, the middle wiring for the switch should be ground, not 12v. I remember I had to do that when I installed it, but never changed my diagram.
miller, its really not hard man, just follow the lines and connect the dots.
Old 06-06-2009, 11:59 AM
Ok I'm gonna go for it tonight. Thanks guys!
Porscharu914
14
01-20-2016 10:45 AM
kalikid06
09-13-2015 05:48 PM
97gmc
22
09-08-2015 10:56 PM
muncie21
09-07-2015 09:55 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: ls1 fan wiring???
