LS1 EDIT?
Old Jul 29, 2003 | 09:45 PM
ThunderZ28's Avatar
12 Second Club
Default LS1 EDIT?
SORRY GUYS NEW HERE, BUT I WAS WONDERING WHAT IS THIS LS1 EDIT. NEVER HEARD OF IT BEFORE, ANY INFO WILL BE HELPFULL.
Old Jul 29, 2003 | 10:04 PM
99Silver6.0's Avatar
Default Re: LS1 EDIT?
Kinda like the Hypetech Programmer but quite a bit more versatile. It is a bit complicated but once you use it a while its easy. The program runs on a laptop instead of a standalone hand-held programmer like the HPP3. Its not really cheap either.
Old Jul 29, 2003 | 10:13 PM
ThunderZ28's Avatar
12 Second Club
WHAT AM I LOOKING AT $$$$$$$$$ WISE?
Old Jul 29, 2003 | 10:21 PM
XLR8NSS's Avatar
Adkoonerstrator
Check it out here <a href="http://www.carputing.com" target="_blank"><font color="red">www.carputing.com<!--color--></font></a>
For a single vin locked cable it is $550 and that includes the software.
It lets you change everything the other programmers do and stuff you'll probably never fool with.
You'll also need a laptop to use it or I guess a desktop would work if you had it in the garage or something.
It is not nearly as easy as plugging in a programmer like a HPP3 or Predator but, it is manageable with a little guidance from people who haved used it.
Old Jul 29, 2003 | 10:25 PM
ThunderZ28's Avatar
12 Second Club
THANKS ALOT FOR THE INFO
one03sierra's Avatar
Formerly one92rs
what kind of mods are you looking to do.if you are planning on going with heads-cam-supercharger then i would go with edit. if not then i would go with the predator.edit is tops though
Old Jul 29, 2003 | 10:27 PM
ThunderZ28's Avatar
12 Second Club
SUPERS IN THE FUTURE. HAVN'T THOUGHT ABOUT HEADS. DONT HAVE ANUFF INFO ON THE MOTOR?
Old Jul 31, 2003 | 02:38 PM
MarineBlue03GMC's Avatar
Tech Fanatic
Personally I would not get a predator and DEFINITELTY go with LS1edit. I fried and completely destroyed my 2003 GMC's ECU/PCM using a custom file from my predator (which was sent to me by Diablosports tech people!)
I was without transportation for a week while the dealer waited for the part, which was luckily covered under warranty. Anyway unless you want to risk frying your computer DONT get a predator.
Old Jul 31, 2003 | 04:11 PM
parish8's Avatar
single digit dreamer
once agian i would like to let you know that you can toast your PCM with edit, several people have done it. if you loose your conection during a program it may lock up your PCM for good and your truck wont run.
like others have said, hpp3 or one of the other programers for a bolt on truck or edit for bigger projects like blower or heads and cam.
Old Jul 31, 2003 | 04:56 PM
Tech Fanatic
Im sure thats possible BUT my main point is that a custom written tune from Diablosport CAN fry your trucks ECU. THats exactly what destroyed mine.
I had been using my diablo for a few months with NO problems and I really liked it. Then I got a custom file from diablo that somehow was corrupted! After attempting to install it on my truck the problems began.
I just think relying on someone else to tune your engine through the internet/email is a risky proposition. One that can be avoided with LS1edit.
The predator also is very limited as far as programming goes.
