ls1 edit?
Your truck motor is considered an LS1. LS1 Edit will work on your truck also.
Esentially it is a program and OBDII cable adapter that allows you to modify your stock PCM in a ton of different ways. It is kind of like an HPP3 or Predator on crack! You use a laptop to make the required changes then upload the new file into your PCM.
For a truck that will never see many mods I am not sure it is worth it but if you plan on any decent amount of mods I would recomend it over any other PCM tools IF you have a tuner in your area or have a decent amoutn of computer and car tuning knowledge.
For more info check the PCM section of LS1Tech.com and www.carpputing.com which is where you would purchase it from.
FormulaZR
Sep 14, 2015 05:23 PM
brandon_6667
Sep 6, 2015 04:49 PM
