LS1 conversion
Old Sep 8, 2003 | 09:38 PM
surfnado8's Avatar
Default LS1 conversion
does anyone know what all would be involved in converting a 4.8 to run an LS1/LS6 topend?
Old Sep 8, 2003 | 11:03 PM
Ryan23silverado's Avatar
Default Re: LS1 conversion
topend? i.e. heads and intake manifold?
if that is what you are talking about, then you will have to swap over to F-body (LS1) engine accessories. To avoid having to spacer anything, I would buy an F-body harmonic balancer to do the swap. The truck harmonic balancer sticks 5/8" further out than the F-body. The balancer is what everything has to line up to, so if you retain the truck balancer you will have to spacer all of the F-body engine acc. outward 5/8".
The heads will bolt right up, but you will be dropping compression ratio with the LS1 heads.
You might just swap in a real LS1 for a little bit more cash. Use the truck balancer and engine accessory brackets and everything will line upi fine. All of the same bolt holes that the truck uses to mount things is on an LS1 block -in the correct spots too
Silver8ado
Sep 30, 2015 11:42 AM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
