ls1 cam and head package
Old Dec 13, 2009 | 04:43 PM
chevy_713's Avatar
Default ls1 cam and head package
i need you opinion with this package do you think this will work good on a ls1 5.7 engine in a 2002 silverado.. with headers springs 660 lift pushrods 3600 stall 373 gears air intake and fast intake with underdrive pulley and i mite but 150 shot nos.... and what time ill hit in the 1/4 mile thanks
Speed Inc Stage two ported 799/243 casting
Rev Stainless steel 2.02 intake 1.575 exhaust valves
Patriot dual spring kit
Titanium retainers
spring seats
valve seals
super locks
Flow 300 cfm @.600 lift
59cc
Comp Cams LSR Custom ground Camshaft
Aggressive street/strip camshaft
INT/ EXH
Duration @ .050 240 244
lift 1.7 ratio 624 624
LSA 111
ICL 109 +2 advance
Old Dec 13, 2009 | 04:57 PM
00ChevyScott's Avatar
Wearin' da big hat
If you spray out of the hole, that setup should run really good.
Running N/A, depending on the compression ratio you're gonna have, it might be a bit slow out of the hole because of that big cam.
Old Dec 13, 2009 | 05:04 PM
chevy_713's Avatar
ya its a 11.5 to 1 ratio
Old Dec 13, 2009 | 08:26 PM
budhayes3's Avatar
PT's Slowest Truck
Seems like a well matched engine combo, as far as cam selection to heads and compression ratio, but I think you may actually want more converter and gear with that setup...
Old Dec 13, 2009 | 08:29 PM
Wearin' da big hat
Don't forget that converter is gonna flash a lot higher on the spray
Old Dec 13, 2009 | 09:06 PM
budhayes3's Avatar
PT's Slowest Truck
true that...
Old Dec 13, 2009 | 09:16 PM
chevy_713's Avatar
any estimated times at the 1/4 mile
Denali08
Aug 9, 2015 04:34 PM
jaypowe11520
Jul 29, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
Black-Syde
Jul 6, 2015 02:12 PM
