ls1 cam and head package
i need you opinion with this package do you think this will work good on a ls1 5.7 engine in a 2002 silverado.. with headers springs 660 lift pushrods 3600 stall 373 gears air intake and fast intake with underdrive pulley and i mite but 150 shot nos.... and what time ill hit in the 1/4 mile thanks
Speed Inc Stage two ported 799/243 casting
Rev Stainless steel 2.02 intake 1.575 exhaust valves
Patriot dual spring kit
Titanium retainers
spring seats
valve seals
super locks
Flow 300 cfm @.600 lift
59cc
Comp Cams LSR Custom ground Camshaft
Aggressive street/strip camshaft
INT/ EXH
Duration @ .050 240 244
lift 1.7 ratio 624 624
LSA 111
ICL 109 +2 advance
Titanium retainers
spring seats
valve seals
super locks
59cc
INT/ EXH
LSA 111
ICL 109 +2 advance
If you spray out of the hole, that setup should run really good.
Running N/A, depending on the compression ratio you're gonna have, it might be a bit slow out of the hole because of that big cam.
