LS1 build questions
Old Nov 1, 2012 | 07:03 PM
fastjweb's Avatar
Default LS1 build questions
I am building a LS1 for street and strip in my 03 sierra.
Parts so far
99 ls1 block/stock bore
05 5.3 crank and rods/weighed and balanced
Keith Black pistons
ls6 ported pump
Ls7 lifters and trays
etc...........
will a comp 212/218 low lift work better with a set of patriot stg 2 5.3 ported heads, or the patriot ls6 heads?
about how much power should I expect with long tubes and other bolt ons?
Thanks for your time-
Old Nov 1, 2012 | 09:40 PM
dmelvin's Avatar
Parts so far
Keith Black pistons
ls6 ported pump
etc...........
I'd go with a 218-228 intake duration cam with the LS1. If you're going more cubes, you can go bigger with the cam. Also if you're going to be spending the money on the heads, you might as well get a cam with some more lift to make use of those higher flow heads.
Just my .02
Old Nov 2, 2012 | 04:06 PM
fastjweb's Avatar
Thank You
Old Nov 2, 2012 | 09:55 PM
DTHPROOF's Avatar
Sorry I got your text late Jason. My phone was dead and I just got home from work. 230's duration cam should get you into the solid 415-430 rwhp range I believe. With a good intake, of course.
USMCvet0311
Aug 14, 2015 10:28 PM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
Black-Syde
Jul 6, 2015 02:12 PM
