LS timing chain?
Old Apr 20, 2016 | 09:09 AM
Dan Neumann's Avatar
Default LS timing chain?
I'm putting a new cam/lifters in my 2000 4.8 along with fresh 862 heads on it. Want to put a new timing set on it also. Anyone use the Cloyes C3210 or PCI TS33210 sets? If so what's your feedback?
Old Apr 20, 2016 | 10:03 AM
03sierraslt's Avatar
I have a Cloytes but mines a whole timing set. It's a Hex adjust. The stock timing sets suck. They have way too much slop.
Old Apr 21, 2016 | 07:28 AM
I just want a better than stock set. Some say use an LS2 chain but i'm thinking with 240,000 miles a whole new set would be better, gears and all.
Old Apr 21, 2016 | 07:33 AM
I am pretty sure almost anything is better then stock, I would get a whole set as the stock gears even with a good chain still always seem to have excessive slack. I would like to measure how many degrees off a stock set is when loaded, I am going to do that next time I have a chance. I bet its at least a couple degrees which is significant.
Old Apr 21, 2016 | 09:27 AM
Phillip123's Avatar
Cloytes are fine. I'd go with them. However, as long as it's not stock it's fine.
Old Apr 21, 2016 | 09:47 AM
FFDP's Avatar
Even though stock chains all have slack, it's pretty rare that you hear of someone ever having a timing chain issue. With all these guys just slamming junkyard motors and running them, the chains normally never come up in the conversation of why the motor blew.
Old Apr 21, 2016 | 10:16 AM
Very true, problem is if you try to actually spec a cam for your combo it won't keep the same valve events with that much slack in the timing set.
Old Apr 21, 2016 | 11:05 AM
George C....'s Avatar
Formerly ScreamingL
I have a 1200mile ls3 cam im not using
Toss a dampener on motor and helps with slop
Old Apr 21, 2016 | 11:42 AM
Yes, as George pointed out the dampeners do help however it will not effect the retard that the cam would see under load.
Old Apr 24, 2016 | 01:37 AM
lxcoupe's Avatar
GM LS2 chain and yes the TFS dampener because it's good insurance and inexpensive. I put one on mine.
You can replace the gears but most don't...you'll want the removal tool for the lower but I've seen guys do it with 3 jaw pullers.
