LS naming convention
Old Feb 12, 2007 | 12:26 PM
Lord Aries's Avatar
Default LS naming convention
How does the LS naming convention work? I almost always hear every GM V8 in our trucks referred to as an LS1 i guess as in LS1 Genration? But, in like my case have 2003 Truck is it an LS1 or like an LS2, LS3, etc ,etc…??? I am getting some custom badges made and don’t want to advertise the wrong thing. LoL
Thanks Guys!
Old Feb 12, 2007 | 12:36 PM
NyteSnyper's Avatar
Seeing as how you have the 5.3, your engine is the LM7. (Pretty sure on this, but im sure you could look it up) it is, however as you stated a Gen. 3 Small-Block Engine (like the LS series)
Old Feb 12, 2007 | 01:03 PM
TXsilverado's Avatar
your either the lm7 or l33. most likely the lm7. the l33 was the aluminum 5.3
Old Feb 12, 2007 | 01:32 PM
Lord Aries's Avatar
So would a set of LS1 badges be a bad thing? LM7 just doesn't sound right... LoL HEre is a picture of the badge design i am looking at...
Old Feb 12, 2007 | 01:44 PM
kbracing96's Avatar
But its not a LS1. A LS1 is gm engine designation code for the all aluminum 5.7L motor in the F-bodys and Vettes. The code for the 5.3 is like said above, a LM7. That's proper terminology
The badge does look cool BTW, but you need to swap in a LS1 (5.7) to be accurate.
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes, it's poser unless you have an LS1. You have the LM7 which is in the LSx series of generation III engines.
Old Feb 12, 2007 | 02:30 PM
Lord Aries's Avatar
Shot that strue, i forgot the LS1 was specificly the 5.7... hhhmmm... I have an idea now though, i'll see if i can get him to redraw it and show guys...
Old Feb 12, 2007 | 02:43 PM
12secSS's Avatar
Here is the naming convention for GM engines:
Lxx:
L code = RPO engine catagory
xx code = next sequential designation (no rhyme or reason, it is just issued the next alpha/numeric characters)
If you look in your glove box, you will see a list of three character alpha/numeric codes. Find the code that starts with L, that is your engine code and states what engine you have. Each of those codes represents what option your truck came with, example: Z codes are suspension aka: Z71, Z88, ZO6, Z28, ZR1, etc ...
The reason why all Gen3 engine, and also Gen4 engines are referred to as LS1 or LSx is due to the fact that the LS1 (debut in the 1997 Y-Body) was the first, in a long series of next generation engines to come. Hence the auto industry nicknamed all the proceeding Gen3 platform engines either LS1 style/type or LSx ... notice the small x, LSX is the GMPP new block, capable of supporting 500 CID. Truthfully, these engine should be called Gen3 (1997-2004) or Gen4 (2005+).
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
OHsixLS3
Sep 25, 2015 04:38 PM
97_ek
Sep 23, 2015 09:16 PM
dhorner77
Sep 11, 2015 05:10 PM
