LQ9 versus 2002+ Z06 cam specs
Old Dec 25, 2003 | 10:19 AM
WhiteDiamond's Avatar
Default LQ9 versus 2002+ Z06 cam specs
Does anyone have the LQ9 cam specs? I found the Z06 cam specs and haven't been successful in locating the LQ9 specs.
Thanks
Sorry guys, I must have been doing something wrong in the search function. I found this info posted by Witt1 a while back.
LQ9 cam specs are .479/.467,207/196,116.LM7 or 5.3 cam specs are .466/.457,190/191,114.You might see some performance increase,but I doubt it would sound very different.Any horsepower increase would be in the 4400-5800rpm range,I don't think you'd lose any bottomend power,but I doubt you would see more than a 5-7hp increase on a stock engine.You can do much better with an aftermarket cam.
Old Dec 25, 2003 | 11:08 AM
BigTex's Avatar
I had seen that 196/207 116lsa spec before. I'm pretty sure the LQ9 has the same cam as all current 6 liter motors.
Old Dec 25, 2003 | 07:48 PM
grooves12's Avatar
Isn't the 6.0L cam the same exact cam as in the LS1?? I thought that was what they did when they got rid of th EGR on the LS1, swapped in the 6.0L cam.
Old Dec 26, 2003 | 08:37 PM
That may be true. I remember reading something about that when I was playing with a 98 WS6 a lot. I am thinking about putting a small cam in this LQ9 to work a bit better with a SC, but it is only a thought right now.
Todd
Old Dec 26, 2003 | 09:40 PM
LQ9 cam is the same as a 01-02 f-body and a LQ4 196/207,116,.497/.467.When I gave you the specs before I was reading them directly from Christopher P.Endres book Chevy LS1/LS6 Performance.I typed the specs as they appear in the book only he shows the exhaust duration before the intake,it's marked in the book,but I evidently failed to make that clear in my post.Sorry for any confusion I may have caused.
Denali08
Aug 9, 2015 04:34 PM
OLD BULL
Aug 1, 2015 05:00 PM
06 4.8
Jul 15, 2015 07:17 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
