LQ9 Swap
Old Sep 4, 2018 | 11:36 AM
Mjb97's Avatar
Default LQ9 Swap
Hey guys so I have a 2000 Silverado 1500 with the 4.8 LR4 engine which I’m going to swap it with the LQ9. I’ve been researching and found that when swapping with the LM7 the LQ9 bolts right in, is it the same for the LR4? If not what additional parts will I need do do this swap?
Old Sep 4, 2018 | 11:53 AM
blsnelling's Avatar
Yes it is. The blocks are essentially the same.
Old Sep 4, 2018 | 12:49 PM
Mjb97's Avatar
Thanks, I actually found a LQ9 close by for $1500. I’ll get it and start fixing it up before swapping the LR4
Im thinking some GT2-3 cams with comp 918 springs
Old Sep 4, 2018 | 03:21 PM
RedXray's Avatar
100% Redneck
If the LQ9 has a electronic throttle body with a returnless fuel system... just use the 4.8 intake, rails and throttle body. If the LQ9 comes with a ECM and it has the blue/green connectors... the ECM may not work unless it has the IAC chip soldered on the board, some do some don't. The IAC sensor is needed for the drive by cable throttle bodies. You should be able to use the 4.8's blue/red ECM but you'll need a tune especially If you're going cam, springs headers etc. you'll need injectors too. The duty cycle on the 24# injectors for the LQ9 are almost maxed out stock.
Old Sep 4, 2018 | 04:59 PM
Mjb97's Avatar
Cool, i was planning on using the 4.8 ECM and getting a custom tune. Any recommendations for the injectors?
Old Sep 4, 2018 | 07:26 PM
FFDP's Avatar
Factory 8.1 injectors are 31 lb/hr and swap right in and the correct data can be pulled right from one of those files when it gets tuned. That's an option if you are more on a budget or you can get larger if you require them.
Old Sep 5, 2018 | 08:30 AM
blsnelling's Avatar
8.1 marine injectors are 42#.
Old Sep 5, 2018 | 04:45 PM
FFDP's Avatar
For whatever reason I've noticed several people on the tuning forums having issues with the marine injectors. The data that people used was always off or they couldn't make them work.
Old Sep 5, 2018 | 07:25 PM
Mjb97's Avatar
Ill probably go with some different ones than the factory 8.1 in case I ever want to do forced induction.
Old Sep 6, 2018 | 02:27 PM
blsnelling's Avatar
I've had them in my truck without issue for 30K miles.
PSWired
Feb 23, 2015 09:06 PM
LT4BLAZER
Dec 22, 2011 03:22 PM
NicD
27
Mar 27, 2010 02:43 PM
chris04
Jul 23, 2009 12:02 AM
Wong
May 21, 2006 09:59 PM
