lq9 in and its a dog!!!!!!!
Old Feb 13, 2007 | 05:18 PM
  #21
onebadrubi's Avatar
Your front o2's, the only ones jesse turns on, are in the header collector. Which means open headers doesnt matter. Unless your set-up is different.
the fuel pump is just insurance.
Old Feb 13, 2007 | 05:27 PM
  #22
Yeah,just the front o2's are the only ones I'm using but when I say open I mean nothing but headers I'll have to wait till friday to get my true duals run. Jesse said the stock pump is worth about 385 HP. And I dont know if thats at the wheels or crank, but I should be making 385+ to the wheels. I also now have 2 filters on the truck now, is this impedeing my pressure??
Old Feb 13, 2007 | 07:48 PM
  #23
Quik's Avatar
5 year bitches!
ditch the 42s and get some 30s and a real tune
all problems should be solved then
Old Feb 13, 2007 | 08:23 PM
  #24
How does a supercharged engine run on lets say 60lber's when its not making boost?People on tech upgrade to 42's all the time.I think its my lack of fuel not too much injector.
Old Feb 13, 2007 | 08:30 PM
  #25
blake2kz71's Avatar
theres also a guy in gadsden that does tuning, im not positive if he does dyno tuning or not but his business name is Dr. k's. theres also a guy in GA i know that is an ls1 guru that uses hptuners so if your trying to find a tuner somewhere close i know a few people.
Old Feb 13, 2007 | 08:48 PM
  #26
Never heard anything good about Dr.K ,I may try to get Gomer to tune it.I'm gonna see how it does after I get the exhaust run on it and the o2's can actually get hot and do what there supposed to do. I went to advance and run a diag. it was throwing codes on both front o2's. I'm gonna get my *** busted runnin strait headers.
Old Feb 13, 2007 | 08:51 PM
  #27
blake2kz71's Avatar
i have a few 02 sensors you could have if you want them. i duno if they work or not though. i only know of 1 person that let him tune their truck but his truck was pretty much stock. just a suggestion, iv never even met the guy so i duno.
Old Feb 13, 2007 | 09:30 PM
  #28
Zick's Avatar
I doubt your running out of fuel. My old setup only used about 85% of my 31lb injectors.
You need to find somebody with a tuner and scan it and see what's happening. There are just way too many variables that can cause it to run bad.
My guess is that it's need better tuning.
Old Feb 13, 2007 | 10:18 PM
  #29
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by dirt_track_racer_81
the 42 SVO's are way too be big for that..did you tell him that they are just 42lb injectors or 42lb SVO injectors..because the 42lb SVO injectors are actually about 48.xx lb injectors because they are rated for 43 psi fuel pressure..and your truck is running 58 psi..
Originally Posted by 1969x11
They are 42lb svo's and its a wait4me tune, Jesse said he could tune for the additional size??
If Jesse misunderstood the injectors to be 42# and not the 42# SVO's then your tune would be very rich. With a high load and low rpm, such as in 5th or 6th gear it would be a dog.
If you have a way to log your O2's that would give you a big clue. A wideband would be even better.
gmcyukon
Oct 5, 2015 06:20 AM
Wolftrk99
Oct 2, 2015 08:17 AM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
The_W
Oct 1, 2015 02:35 PM
