LQ4 with shaved heads
Old Sep 14, 2005 | 09:28 PM
white1's Avatar
Default LQ4 with shaved heads
If I shave a set of 317's .030 and home P&P them, will I be pretty close to a LQ9?
BTW Im also adding a 3000 stall and hopefully a 218/224 .562/.568 cam
Old Sep 14, 2005 | 10:37 PM
yes, but you'll prolly have to use shorter pushrods
Old Sep 14, 2005 | 10:40 PM
litreddevil's Avatar
Banned
No Shorter Push Rods Just Put .030 Shim Under Rack That Holds The Rockers.
Old Sep 14, 2005 | 10:43 PM
99Silver6.0's Avatar
Shorter rods or shims and use some thinner head gaskets. Itll put you close.
Old Sep 15, 2005 | 12:18 AM
desTRUCKtive's Avatar
I shaved .030 0ff and used the felpro 1041 gaskets which are about .41 thick, I think that when I calculated everything it put me a little close to 10:1 I think I had about 9.9X dont remember but it will out you close. you will need to run some shorter pushrods .735.
Old Sep 15, 2005 | 09:12 AM
white1's Avatar
Ill need shorter pushrods with the cam? When I did my first cam swap with the stock heads it sounded like a Singer, when I did the second cam and shaved heads the noise went away
Old Sep 15, 2005 | 09:47 PM
Youll actually want a bit longer for the cam. But since you want to mill 30 thou down, that will make up for the smaller cam base circle. There are calculators on the net for figuring proper rod length.
thunder550
Oct 8, 2015 04:53 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
darnie
Aug 10, 2015 10:25 AM
NuckenFuts
Jul 9, 2015 08:45 AM
