LQ4 or LQ9 Rods ?
yup that means its a 04 or newer also IIRC
the bolts that are underneath the intake manifold were the knock sensors are mounted there should be 10 of them
I will take a look and see what I can see.
Wanting to put a set of 243 heads and an LS6 cam in my 2500 HD and was wndering if it had the bettr Rods due to compression going up. Any opinion on these mods? I am wndering if the head swap is really worth about $650 for a new set from GM?
9 Second Truck Club
2005 truck made in 2004 should have the big rod. The rods won't matter until you get past 750 HP. Actually the lighter rods are better for lower hp because they weigh 50 grams less. You can feel the difference in response...
