LQ4 Changes/Differences
Old Aug 17, 2010 | 04:22 PM
blsnelling's Avatar
Default LQ4 Changes/Differences
Have any changes been made to the LQ4 shorblock over it's production life?
Old Aug 17, 2010 | 04:25 PM
DV2000NJ's Avatar
13 Second Truck Club
I believe that the only differences are that the '99-'00 LQ4s had the longer crankshaft and will only mate up to the 4L80E, and in 2005 they got the stronger connecting rods that were in the LQ9.
There might be more, but I think that's it.
Old Aug 17, 2010 | 04:29 PM
blsnelling's Avatar
The con rods is what I thought I had read something about. How big of a deal is that for someone like myself looking to swap to a 6.0? It will be built similiarly to my 5.3 with a little larger cam and 3200 stall, nothing radical.
Old Aug 20, 2010 | 01:29 PM
hog's Avatar
hog
If you use a 2001 and new LQ4 or LQ9 you will just pull the old 5.3 out and drop your 6.0 in. Its that easy.
For model year 2004, the LQ4 got the full floating wrist piston pin design that was introduced with the 2002 LQ9 that uses snap rings to hold the wrist pin in position. This change to full floating pistons helped the LQ4 extend durability beyond its original 200,000mile validation.
These pistons are recontored and feature coated pistons skirts to allow a tighter piston/bore clearance. The coating started MY 2003.
In 2004 or 2005 the LQ4 got the LQ9 rods as well.
peace
Hog
Old Aug 20, 2010 | 01:43 PM
blsnelling's Avatar
Thanks hog. It'll be interesting to see which rods I got, since it's supposed to be a 2004 engine.
Old Aug 27, 2010 | 10:38 PM
flossinon_24s's Avatar
04.5 up also use different headbolts. 99-04 use 3 different length bolts where as the 04.5+ use 2 diff bolts
Old Aug 27, 2010 | 11:08 PM
blsnelling's Avatar
My '04 shortblock had the LS2 rods, full-floating wrist pins, and coated piston skirts. Got lucky and got all the upgrades.
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
