lq4 bolt ons
Old Oct 22, 2013 | 09:52 PM
bedtwd's Avatar
Registered User
Default lq4 bolt ons
I have a 99 Silverado 2500 4x4 with the lq4 6.0L
I'm wanting to know friendly budget or junkyard bolt ons I can do. Would lq9 317 heads do good. I love the lsx-t intake but not budget friendly. Any ideas? I'm just interested in intake manifold, heads, cams, throttle body. I already plan on Lt headers and custom tune. Any help would be great. Thanks!
Old Oct 22, 2013 | 10:45 PM
grey matter 04's Avatar
13 Second Truck Club
Being your trucks a 99 it has iron heads. Swapping to 317s will gain some flow/HP or 243/799s will gain some power also a compression bump. Since the heads are off swap lifters and cam. Cam choice depending on your needs!
LT headers are worth the gain.
All depends on your needs and budget how far to go!
Old Oct 23, 2013 | 12:15 AM
gamble686's Avatar
Heads:243s
Cam:220/224 .567/.571 LSA112
Intake manifold:NNBS intake manifold
throttle body: PTM92mm cable driven
Old Oct 23, 2013 | 05:57 AM
bedtwd's Avatar
Registered User
What's the difference in 317 and 243 heads? Both aluminum? I want a cam that's gonna have a decent lope but still have my low end torque. Its my daily deal driver.The nnbs intake is it a truck or car intake?
Old Oct 23, 2013 | 06:16 AM
bedtwd's Avatar
Registered User
Where's a good place to buy these cheaper. Junkyards have them? With the nnbs intake do I need new injectors or will my stock ones work. Will my stock pushrods work with this setup?
Old Oct 23, 2013 | 10:22 AM
cosb's Avatar
Nnbs intake is in the newer gm trucks, here's a link, might be a little bit different for a 99's "how-to" 03-07c NBS TBSS/NNBS intake swap - Chevy Truck Forum | GMC Truck Forum - GmFullsize.com
Stock injectors will work but you will need to modify ur fuel rail and push rods will also work but if you have future plans for 500+ hp you should upgrade them anyways when/if u do a head swap.
Old Oct 23, 2013 | 04:37 PM
GREENSIERRA's Avatar
Originally Posted by gamble686
Heads:243s
this sounds like a very good setup but I would add a 3200-3600 converter
Old Oct 23, 2013 | 06:26 PM
You will need injectors!
I run 31s in my 6.0 bored 30 over with a 224cam
And full bolt ons.
I am at 100% duty cycle at 6300rpms on 31s.
Stock will not cut it !
ClintBeastwood
Aug 31, 2015 05:30 PM
slowlsx
Aug 10, 2015 05:33 PM
darnie
Aug 10, 2015 10:25 AM
4B11T
Jul 13, 2015 03:48 PM
NuckenFuts
Jul 9, 2015 08:45 AM
